Single piston DV on a R
Stoned
Can you use a single piston DV on the R without problems?
I'll be needing to use one while my BOV is sent back to be sorted out. I've got a baileys DV from my old Fiesta Turbo. The valve works fine but while it's on the GTI-R idles a bit lumpy and frequently the revs dip below 800 where it suddenly kicks into life again
jasegould
Yep, I agree, i hAD ONE THAT FOOKED MY IDLE UP WELL AND TRULY
Stoned
lol I would matty but your metal bung was so big I ended up having to use a HAMMER to get it in. It's not comming out again so I dont have a lot of choice in the matter.
Can I reconnect the recirc valve without connecting the recirc pipe?
It'd be like a atmospheric DV without the hissing noise :)
Stoned
So rather like a single piston DV then lol
I cant win in either situation. I guess ill just drive around off boost until I get my BOV back.
skiddusmarkus
Dunno,never ran a single piston but tried a recirc on only connected on one end to see if a problem I had was BOV(it was)and off boost it sounded like it was running on 3.
ashills
i ran the standard recirc to atmosphere when i first got car as i didnt have a adapter to recirc it with and it just ran very rich all the time
if uve got a AFC or emanage etc there is ways to use single piston DVs if u really wanted to
Mr Overboooost
i had a bailey single piston BOV for a while with no problems whatsoever :?
cheers
gary :)
Stoned
Cheers lads, I dont want to use it at all. I want my shiny BOV to work and use that :?
But as long as it aint damaging my car in the mean time i'm happy
Thanks for the advice
