Side trim removal?
smcnairn
Prob been covered before but cana find it in the search. How to remove the side trim (bump strips) do u have to remove the door cards and get it from the inside? :?:
N
Ninj-r
Also read somewhere else on here that there is a hole somewhere in the door after you take them off which will need sorting.
smcnairn
Your right there are holes, im just needing mine off to get colour coded so they will be going back on. Any one know where to get similar double sided tape to put them back on with?
CruiseGTi-R
On my old car I made the mistake of using double sided foam tape which is white in colour. You could just about see the white foam behind the strip.
I tore it off, roamed around a few DIY stores (B&Q etc) and found some thinnish black foamed double sided tape with a strong tack to it. Much better.
Not had a look at pulsar strips though.
