shimming up
pulsar kid
Before you read this, i dont know how to do it so ive had alook and come up with this. if ive got the cams out can i just take each shim out indervidually measure it and if its worn down replace it with a new one???
also iam after a how to guide on timing my engine back up when i replace my cams back in.
ollydj
you need to check your clearences before you take your cams out. work out the difference, then make a shim or buy a shim to fit. id probabley have a pop at making them as theyre hard and also dear to get off nissan. I made my own with mine and it worked a treat. do a search on making shims as im sure ive come across it on this site somwhere.
dotalot
How did you make the ones that locate the rockers?
