sharing my painfull moment
Trip
Yesterday i had a go to adjust my clutch pedal travel. Those japanese were either on drugs or heavily lacking sex when they designed the clutch pedal.
I ended up removing the drivers seat, plastic of the lower part of the dash board, plastic surrounding the steering column, and unbolting the steering column so i can have better access to the bloody pedal. Crawled upright head first under there with all the weight of the steering column on my belly. Jiggled the column a couple of times to get part of my hands in there and slowly but surely managed to adjust it.
I was so frustrated with all this, that i re-assembled everything back without even testing the fucking pedal. Fired up the engine and found out that i had adjusted it too much and when i press the pedal all the way down, the last few mm of travel were producing a faint ticking sound coming from gearbox. Oh God..:doh: It must have been the clutch cover's "fins" or the trust bearing going in too much and hitting the clutch disk which results in the ticking sound.
Fuck-it .. Like a complete Moron (with a capital M) I had to De-assemble everything again and re-adjust it.
I hope i won't EVER AGAIN come in need to adjust the clutch pedal.
What I found is that because it's hydraulic, it's kinda self-adjusting. You can fiddle with the amount of freeplay before the cylinder engages, but the cylinder only has a finite volume so as long as there's enough free play for it to release the hydraulics look after themselves.
You're quite right though; it's a real b!tch to get in there, and there's no room to get your tools on the adjusting rod.
johnsy
the trials and tribulation's of R' owner ship!
iv just fitted a ss mani and newer turbo, wot a ball ache that was, feckin 'bastard' mani bolt and the one above the alternator had snapped in the head,
shroom
which one is the bastard? the one sort of in the middle that you cant get a ratchet to? I know the one by the alternator was a pain, forgot to disconect battery and got a bit of a shock :(
stumo
I don't see why you had to do all that.....it's an awkward job but it's doable with everything in place....:roll:
johnsy
The worse bolt on the mani is probably the bottom bolt on the third cylinder.
thats the one ,
i think some where along its life someone had superglued it in place ,i gave up after 2 hours of trying to crack the seal with a spanner and screw driver and just put a cobalt 5mm then 8 mm drill bit through the side of the nut
i found it quite easy to extract the snapped stud too, those cobalt drill bits are a life saver plus my grabit stud extactor , i went to my local motor factors and picked up new studs (95peach) and bolts(45p) think nissan wanted summit like £4 a stud
olliecast
i managed to get in, upside down, with my sparco seat bolted in and my 6 point cage in! :)
did have the steering wheel off though.
you sure it wasn`t just the pin in the pedal clicking as it was getting pressure at a different angle?
Trip
i couldn't get any tools in there apart from a spanner size 12. The shaft was turned round with my fingertips 1deg at a time :oops:.
I tried all types of pliers and long noses but i couldn't get the right angle to grip and turn. Being in the garage on my own, i had to literally look by the touch for tools sitting around me.
Tim
Someone should have closed the door and filmed you trying to escape :lol:
I found a pair of these are the best thing for adjusting the rod on the clutch master cylinder ;-)
As stumo said theres no need to take anything out to adjust it! I even managed to do it on a friends pulsar with a fractured wrist in less than 10 mins, although the cast on my left arm did get in the way a little bit :doh:
