britishrallying
Hi,
Fitted AVC-R this afternoon and replaced the vacuum pipes. All works fine apart from im not 100% sure how to set the thing up :lol:
Just to make sure Im understanding things correctly:
Duty is how long the solenoid stays open, therefore the higher the % the more agressive the power through the tubby will be?
Boost is only a target something to aim for, so say for instance the boost was on 0.3kg/cm2 and duty on 70%, would be seeing more of 1bar of boost?
I set it to the above before and got 1 bar there abouts maybe more guage only goes to a bar :shock:
Im aiming for 0.9 - 1.0 bar on setting A, and on setting B around 1.2bar when I get my new clamps for intercooler pipes and spark plugs (NGK rating 8)
So for Setting A (0.9 - 1.0bar) i would need to have:
Boost 1.0kg/cm2
Duty 45%
Setting B (1.2bar):
Boost 1.2kg/cm2
Duty 70%
RPM settings 1.2bar
0 1000 2000 3000 4000 5000 6000 7000
80% 75% 70% 65% 60% 55% 55% 55%
With self learn mode do I need to drive it hard all the time and just drive as normal?
Ive set up car select:
Cyl Spd Thr
4 2 /\
Pressure type setting:
Relative 1
Gear Judge on:
1st 120
2nd 75
3rd 50
4th 35
5th 25
So would these settings be about right? Going to take it up to Hiteq, but not until Feb.
Hope someone can help me out,
Gaz
Boost 1.0kg/cm2
Duty 45%
Setting B (1.2bar):
Boost 1.2kg/cm2
Duty 70%
RPM settings 1.2bar
Cyl Spd Thr
4 2 /\
Relative 1
Gear Judge on:
1st 120
2nd 75
3rd 50
4th 35
5th 25
Gaz
