retepetsir
My new life of Pulsar ownership is not going well at all :doh:
Sorted the radiator problem, engine is running again and seems to sit with good oil pressure, water temp, etc.
However, something mechanical is now definately not right. I took the car out for a run around the block to warm it up and bit and something started rubbing/biting. As if the brakes were binding? Not 100% sure it is that though. I ran out of time last weekend to check anything out.
I've just been out to take the car for a run and see if I could possibly free up the problem, using the brakes a few times, etc but its now got even worse.
There was a fairly loud mechanical scrape/bang coming back to the house so I stopped the car and had a look. I could see no signs of brake disc problems, etc.
It was so bad that outside the garage the car wouldn't even move. I could move it backwards but then it was pretty much stuck going forwards. Eventually I just upped the revs and slowly got it moving forward, but there is definately lots of resistance coming from somewhere.
Any ideas?! I'm not happy
