Semi complete guide to R suspension parts
Status
Not open for further replies.
Sirnixalot
Coil Overs
JIC Magic (www.checkerflag.co.jp)
Tein HA (www.checkerflag.co.jp)
Whiteline (www.whiteline.com.au or Power Station in the UK)
Lowering springs
Dow Max (www.checkerflag.co.jp)
RSR Ti2000
F:3.25kg/-mm R:3.00kg/-mm
RSR down
DR21 sport
F:3.2/2.6kg-25mm R:2.8/1.8kg-20mm
DR21 supersport
F:4.4/3.4kg-40mm R:3.6/1.8kg-25mm
DR Racing
F:5.8/3.8kg-50mm R:5.0/1.8kg-40mm
Struts/Inserts
Koni (www.whiteline.com.au or Power Station in the UK)
KYB (www.checkerflag.co.jp)
Nismo (rebadged KYB’s) (www.checkerflag.co.jp)
Upper Pillow Ball mounts
Tein (www.checkerflag.co.jp)
Cusco (www.checkerflag.co.jp)
Anti-Sway bars
Bumpsteer kit
Power Station/Whiteline (www.whiteline.com.au or Power Station in the UK)
Handling Pack
Lower control arm brace
Whiteline (can clear 3” down pipe) (www.whiteline.com.au or Power Station in the UK)
Strut tower Braces
Cusco (front and rear) (www.checkerflag.co.jp)
JIC Magic (front only) (www.checkerflag.co.jp)
Nismo (front and rear) (www.checkerflag.co.jp)
Whiteline (front and rear) (www.whiteline.com.au or Power Station in the UK)
Poly-urathane suspension bushes
Ashill's (see post below)
Power Flex (no idea)
If anyone else has anymore stuff or specifications to add PM me and ill add it to the thread
ashills
Not advertising before u start moaning but heres all the bushes i can get that can be changed to poly ones
Front Lower Wishbone Front Bush, Incorporating Bonded Thrust Face
Within Each Flange, Kit of 2
Front Lower Wishbone Rear Bush, Kit of 2
Special Caster Increase Version, Kit of 2
Power Steering Rack Mount Bush, Kit of 2
Front Anti Roll Bar to Chassis Bush, Kit of 2
16,22,24,25,26,27 & 28mm available, Please measure
Front Anti Roll Bar Link Pin Bush 1 of 4
Rear Suspension Arm Inner/Outer Bush, Kit of 8
Rear Anti Roll to Chassis Bush, Kit of 2
**12,13,14 & 16mm available, Please measure
Rear Anti Roll Bar Link Pin Upper Bush 1 of 4
Rear Trailing Arm Bush, Kit of 4 1 only
Sirnixalot
not all are created equal but to find that out one person would need to review all these things.....certainly wont be me. I dont know which is better than who.
i have got Tanabe Sustec shoicks on mine which seems to be a good fast road kit.,
not adjustable btw.
nick
Status
