Ok, had a few different companies views on this, and a couple of mates, but being the cautious type I like to seek out as much advice as I can before I do anything.
If you've seen the question about the gauges/a pillar that can hold 3 gauges, this is related.
At the minute I'm looking at doing the usual R mod and turning my boost up to 1 bar. The car at the minute is standard with the exception of exhaust, HKS mushroom filter, uprated plugs and blow off valve.
I'm advised that to turn the boost up to 1 bar I need the following:
1) New uprated leads (although not all agree on this one)
2) Uprated fuel pump
3) In car adjustable boost gauge (don't want a bleed valve) that I was thinking about mounting in the centre console where the standard fit gauges sit.
As far as I remember thats all thats needed, along with a proper set up. I'm told that these mods should see me around the 280bhp mark?
Is there anything I'm missing here, anything else I should take into consideration (front mount will come next before any other big power mods) and any general advice on fitting/companies/cost I should bear in mind?
As always, appreciate your help
Paz
Paz
