jasegould2002 said:
I cant see the rear spolier making that much difference, at the end of the day the GTIR has the aerodynamic qualities of a brick :lol: U cant really compare it to a F1 car as they are designed around aerodynamics, the GTIR is designed around some old bid going down the shops to get the weekly shopping!!
the air that goes over the top of the car will get sucked to the back of the car and slow it down a lot due to the flat rear bootlid if there was no spoiler. this will also mean that if the air from ontop of the car is coming down then the air underneath wont come up as far.. you get lower presure over the top of the car. the faster you go the bigger the effect.. leading to an unstable ride at speed.
(for proper 'flip' aero dynamics, see the first release of the audi TT)
the key to the rear spoiler is the over hang. the low presure area that the spoiler creates under it, helps to drag the air from under the rear bumper up to the boot and to keep the air going over the top going flat along the roof line.
this way both jets of air (top and bottom) will meet up having traveled a similar distance to each other. the net effect is that if they both have the same distance to travel then there should be less of a low presure point over the roof line of the car.. keeping you on the road.
like i said above. not really much downforce, more of an anti lift spoiler. 'spoiling' the airflow over the crude aerofoil of the cars shape.
in a nut shell.. dont take it off!
L.
