Gray
Took my car to Hyper SR today for them to fit a decat, oil change and fit and setup an emanage an map the boost to 1.3 bar also install some 550cc injectors
They did the oil change and the decat even did it so the light went off the dash for the temp sensor
They installed the injectors then installed the emanage then took it to set it up
They came back and said it was runing way lean after 4.5k even on standard boost aswell as 1 bar and 1.3
They thought the injectors i had might be buggered so they put the standard ones back in - same thing was happening
The checked the fuel pressure and it was good, they changed the MAF - still happening
They bypassed the emanage to see if it was that and it was still happening
They checked the ECU for fault codes and there werent any
They spent about 3 or 4 hours trying to figure it out but couldnt they said it seems like it must be being electronically cut after 4,500 rpm but not sure why (but they still dont really know) - so today cost me nearly 500 quid and all i got was an oil change and decat put on which is fair enough for the amount of hours they spent on it
I dont wanna take it back tho for it to cost me anther days labour and them not find the problem - they mentioned testing the injector resistor pack if i brought it back and a few other things - it seems really weird as the car runs fine and you wouldnt even know it was running lean im lucky ive not melted any pistons i guess
Feeling pretty low at the mo cars pissing me off - Any one any ideas about what could be wrong
