antgtir said:
I presume you mean that your R is an M reg 94 year? if this is the case then in theory mine wont have these balance screws too.
I wouldn't play around with them id just be interested to see the kind of differences across the board. I suppose if these are screw type adjusters then Mr Nissan will only be able to fine tune them as much as we would (physically that is) however i suppose with his £k's computer he'd be able to tell differences in a nats whisker lol
Paul if there aren't any adjusters in there maybe the throttle body adjuster design changed to an auto type worked from the ECU? or internal mechanical type worked of pressure ratings? just poking in the dark on that one lol.
Ant.
That's right mate, mine's an April 94 (L).
As for the electronic control, I wouldn't expect so as, they'd need a solenoid etc.. on each throttle body, to adjust them. Of course, there is ecu idle control as a whole, using the ICV or whatever it's called on the GTiR. Afaik, this lets air in after the throttle bodies though ?!
I'd expect that the TB's are assembled at the factory with a tolerance in mind so, they shouldn't need to be adjusted in their 'life time' ?!
