before you remove head, take spark plugs out, as the liners quite often lift which causes the bottom cylinder seals to leak! be very carefull when lifting head from block as its the suction which lifts the liners. and whatever you do DO NOT turn engine by crank once head is off, as this will bugger them for sure! good luck
