daz
purchased a roller bearing turbo from universal turbos a direct replacement for the oem unit same size housing just slightly bigger compressor and exhaust turbines. with the original(now knackered) turbo the peak boost was at approx 3800rpm on the rollers nothing changed bar the turbo and now the peak boost is at approx 5000 - 5500rpm. took the car back to john noble motorsport where they took the turbo off checked the wastegate and the general apperance and fitting of it and said it was fine, put the oem actuator back on and the car is still not getting to full boost till 5000 ish rpm????????? :shock: anyone have any idea why this is??? could it be the trim on the turbine or something else. ps car was still running roughly the same horsepower as with the oem unit but because the boost is not reaching its peak until much later the torque has dropped by about 30 llb/ft........... ideas :shock:
