I am but regret doing it as they can cause more damage than they are worth if the worst happens. Trouble is the rockers tend to move up AND to the side under rev limiter conditions the stoppers only stop them moving upwards so still move sideways. Could be well off the mark and I'm sure If i'm wrong someone will correct me.
I don't know I've never had a problem on the standard engine, even buzzed at least 8500rpm once when I missed a gear and floored it.
What rpm do you use?
My sunny Gti with sr20det engine really brought my fears of the red line back in check although I would not go out and do it in my pulsars it proved that built n shimmed properly it will last. That thing was never off the red line as it just spun and could at times not change quick enough and it never missed a beat
What turbo set up are you running as normally no need to rev them flat out
