The car seems to kick out a bit off blue smoke when u lay off the throttle and when going down the gears, this is most probably the rings which is a bit of bad news as the engine is only sposed to be about 40000 miles old so would have thought it would of held on a bit longer? also could it be anything else that is causing the smoke? at the moment it looks like a change of rings as cant afford a decent rebuild. any tips would be helpfull.
yet to do compression test.
cheers
cheers
