Right if the engines coming out what should i replace??
samellio
Need to get my engine taken out as the waterpump has started leaking..
Was thinking the clutch would probably be worth changing (as it's only standard) but is there anything else likely to go wrong that i'd be as well changing at the same time? starter, alternator pwer steering pump etc??
Any help much appreciated :wink:
Sam
jiw
sam before you start, their is a how to telling you exactly how to change a water pump, saves a lot of work :wink: jeff
oh and you need not remove the engine :D
samellio
Thanks JIW :wink:
Shall see what the boys at the garage think.. fingers crossed they should be able to do it..
