reverse lights
mad_matty
just a quick newbie question
my reverse lights are not working, they have no power to the bulbs so im thinking.
a fuse/ relay or switch is knackered?
could some kind person point me in the right direction on where the fus/relays are and where abouts the switch is on the gearbox
many thanks
oap-r
I love Rob xxx
Isn't there a switch when you go into reverse that will supply the reversing lights?
Try a search through the archives ;-)
The switch is on the passenger side of the gearbox casing. It's a black plastic teardrop shaped thing with a black cable coming out of it. Not sure this would pack it in though, as it's a very simple mechanism ?! You could check the plug going to/from it !
mad_matty
cheers chaps,
i have had a look through the archieve messages and i couldn't really find anything.
cheers for your help anyways
does anyone no where abouts/ if the reverse lights run off a fuse/ relay? i was thinking that maybe another thing worth checking
petebann
take the plug off the reverse switch mate and give it a feed (i.e just run a bit of wire from the battery positive and put it in the plug) if your lights come on you know you have a faulty reverse switch. If it still doesn't come on, check your fuses. It won't go through a relay.
