I'm beginning to think there should be a PobodY's "What have I broken today" thread... it always seems to be suspension related too!
Those of you that I saw at the NW meet last year may be aware that I had a captive nut with stripped thread on one of my wishbones, and that I couldn't torque it up. It has lasted quite a while like that without any issues.
However, today I found out what happens when it doesn't hold any more and you stomp on the brake pedal (admittedly I may have been on full boost before hand). - The short version is that the wishbone slides sideways and the wheel mashes into the chassis with quite a bit of noise... and damage. :roll:
Yes, that has worn off the front of the side skirt and taken the paint off the body panel... it also coated my tyre with melted plastic.
Don't worry - I worked out how to put it back: Put it into reverse, back up a bit, then hit the brakes to slam it back into place! :twisted:
Here's the culprit:
You can see the one good bolt is holding well...but, the bracket it actually bent now (you can see it in the photo).
This is what it looked like after I tried to straighten it out again:
Before you all start having a go at me, I did take Andy C's advice and try to find someone to helicoil it for me. However, they didn't have a M12 helicoil to do the job, and it seems like a waste to buy the tools for the sake of one captive nut!
I then tried some JB weld to fabricate a new captive nut (essentially just a wad stuck over the hole with a thread cut in it), but that didn't work and just pulled off the body when I tried to torque it up... but at least the bolt doesn't just fall on the floor, and maybe it'll give me a little resistance against the twsity wishbone.
So, is there anyone in the Deeside/Chester area that can help me? Got a M12 helicoil kit I could borrow, or maybe a M14 thread tapping kit and a suitable M14 bolt? Even a garage who can definitely fix it without my having to take a mortgage out.
I don't really want to get into cutting panels to replace the captive nut.
I got all the way to Norfolk and back through the Peak District (we took the scenic route because the R loves those roads) without any issues, so I'm reasonably confident it'll hold for a bit longer yet.
Here's the culprit:
