Removing Front Bumper
nismoboy
there are 2 screws one each side. there just under the wheel arch cover. then 4 plastic clips under the front slats where the number plate is. Then u need to squeeze the 2 release tabs which are directly behind the number plate section inside the engine bay.
Jonny H
Yes these bolts are a complete ass to get too!! If you peel off the arch trim and stick your head in there, look up and you'll see the bolts that hold the front bumper on! Undo those then the 2 securing screws on the number plate then yank away......might be an idea to pull the bumper off too! :roll:
nismoboy
Undo those then the 2 securing screws on the number plate then yank away......might be an idea to pull the bumper off too! :roll:[/quote]
pmsl :)
