Fuse box and main relay.
Connections instead of the original fuse/realy box
Wiring for ignition ON, starting up and gauge cluster
Main wire harness under dash
Master power block. (top right you can see the radiator relay in blue and in-line fuse holder) (please note that the engine bay was cleaned after the pic was taken)
I have another harness which goes to the back connecting the Battery, fuel pump relay/fuse together with a Inertia switch to cut fuel supply incase of an accident.
All the remaining wires i took out from car
Finished product
Also note that i have MSD ignition/coil, Gizzmo shift light with launch control, PLX devices datalogger, oil temp, oil pressure, boost dails, 2 FIA master switches (one in engine bay and one inside), Turbo timer and Boost controller.
I made all these harnesses modualr so i can remove or add anything i want in the future. I also made a custom harness (not installed) which plugs in to an existing connector to give power to the front lights (in the event i want to race at night).
If you are going this route i suggest you study well the wiring of car, plan everything from before then simply plug and play
