mightydquinn
Hello, i've been having a boost problem for a while now, it would only boost to 1.2 bar and would drop to 1 while still accelerating with the actuator pipe off. I checked all the pipes and had it smoked to find i had no leaks. I took the turbo off expecting it to be an actuator fault, i had a bit of side to side movement in the turbo and the turbo specialist told me this was my problem. Anyway i got it reconditioned and also had a 360° thrust bearing fitted. Now i've put it all back together the most it will boost to is 0.7 bar, not happy! I've checked all my pipes again and they are all tight and all seem fine. Anyone else had a similar problem or got any ideas of what might be?
thanks Chris
thanks Chris
