Rebuild?
Sweeny
Im thinking of a rebuild, but don't know what sort of spec to go for.
From my limited knowledge of engines this is my idea :
Forged Piston Kit
HKS Metal Head Gasket
Gas Flowed Fully Rebuilt Cylinder Head
Super Liner Engine Block
New Oil Pump
New Timing Chain
New Bottom End Bearing Set
Re-Ground/knife-edge Crankshaft
Re-Bore 1mm Oversize
Skimmed Head (To Ensure Flatness)
Skimmed Block (To Ensure Flatness)
Blueprinted & Balanced
Super lightweight flywheel
Steel Conrods
Stainless Steel Engine Bolt Set
And all new gaskets, bearings etc.
Ive currently only got hks 264 cams and pulleys, with unichip at 1.2bar.
I know to support this, other stuff is needed like, better turbo, injectors, maf, adj. fuel pressure reg, gearbox etc.
I've had a prices for the engine work from various places all in the region of £5k.
What else is worth doing while its in bits and any ideas of a cheaper way of doin it?
Cheers.
James.
Stoned
What, and your friend just happens to have exactly the same engine and mods as the one in your Car for sale post
Err right....
Sirnixalot
Stuff you should do
Forged Piston Kit
New Oil Pump
New Water pump
New Timing Chain
Stuff you dont NEED to do
Steel Conrods
Sweeny
Excuse me mr 'stoned' but do you think i would be that stupid to put up two posts that contradict each other.
And yes I did put 'im thinking of a re-build' but im very sorry for my incorrect grammer.
My mate hasn't got access to the internet!
I have actually built my car to the exact same spec as my mates, as i was impressed with the BHP increase for little and cheap mods.
Thanks for the interest tho.
Cheers.
James.
Don't need to sell my now as daddy has lent me some pennies. :lol: :D
