rear wiper mod
Ollie-R
How do i move the rear wiper so it layes flat :?:
i pulled the wires off and put them back but i cant get it to stay down :(
Pete
isnt there a nut under the cover on the wipe arm what u have 2 take off and the move the wiper 2 where ever u want it :roll: :roll: :?: :)
JIMMYBACK
Horizontal Resting Rear Wiper Arm
For anyone wanting to know, this is how to convert the rear wiper so it
rests at the horizontal position instead of the naff vertical position.
a.. Remove the trim from the tailgate - it just pulls off.
b.. Remove the rear wiper.
c.. Disconnect and remove the motor and gearbox - 3 bolts
d.. Remove the phillips screws on the motor and gearbox housing.
e.. Pull apart.
f.. Remove all the circlips ( 3? ) apart from the one that holds the
linkage to the arm that sits on the gear (no need to).
g.. You might as well regrease everything while your at it so tap the
spindle out, clean up and regrease - you should be able to rock this from
side to side easily with your finger. Mine was difficult to turn even with a
large spanner (which is why mine was off - wiper stopped wiping!).
h.. THE IMPORTANT BIT - remove the arm that is sitting on the plastic
gear. Pick it up, turn it round 180 degrees and put it back it back on.
i.. This is how the gearbox should be connected back up. But before you
do, drill a 10mm (ish) recess into the plastic just like the one 180 degrees
further around the wheel. This is for the linkage rivet to sit in and if you
dont bother drilling a recess (and thus saving yourself a whole 30 secs!)
the whole assembly will probably be tight when fastened back together. Just
remember not to drill right through!
j.. Now just assemble everything back together using loads of
grease/copperslip or whatever you normally use for lubrication!
k.. If youre like me the old circlips now probably resemble little metal
bananas so get yor hands on some proper circlips around 6 - 8mm diameter?
and put them on. The Nissan ones really are crap.
There thats it. If that doesnt sound easy or doesnt make sense then let me
assure you its a piece of piss.
Any bother just let me know.
Ollie-R
thanks
it took me no time at all to put that bad boy flat :twisted:
