Rear Inner Arches
Smo
Does anybody know if you can buy the inner rear arches for the R anywhere? I've tried Carz2 but no luck. If not I'll just have to get them made up.
Cheers.
antgtir
As far as im aware they do not exist, just as the external rear arch's dont exist for the three door.
I made mine up out of metal sheeting, however on reflection i would suggest getting double of the external 5 door arches and cut to suit on both inner and outer skins.
Ant.
vss irvine
you have to buy a rear quarter to get proper outer arches, and im sure they are jap supply only. last time i saw a quote it was over £260 each.
inner rear arch is part of the body shell, so i doubt you would even get repair panels from nissan?
nimhbk
mine was done done with metal sheeting by a pannel beater, at least this way if you chose the right metal you will know they will never need doing again
I'm guessing you've been told the same as me; there's no point replacing the outer arches unless you're doing the inners too because they are just as rotten.
