Rear hub assembly
keensie
So the hub assembly is off the rear ready to change the bearing and i can only see one circlip is this right?Also as the ABS sensor refuses to budge i had to leave on with loom attached,can this stay in the hub when changing the bearing?.Apart from the ABS everything came apart easily:)
