rear diffuser
It won't hide the tailpipe, other wise how do you think all the exhaust gases will escape?
Under the body of the car, then sucked out by the flow from the diffuser? - You could find that you get a headache when stopped in traffic though...
Given the design of the diffuser, I think you'd more likely get a build up of hot gases where the standard rear box should sit and they'd slowly work there way into the car and slowly poison you, until you crash and burn like Cole Trickles dad. I'm sure an exhaust has to allow the gases clear passage of the vehicle.
olliecast
I've died 4 times in mine now because of the fumes getting into the car.
The airflow increase is well worth the fatality rate I've experienced though :)
Good job I'm a cat (or pussy) with me 9 lives
ray77
I mean to hide the fact that the goose got no "exhaust can", in canada there is a law sayin you got to keep they original car exhaust specs. So they wont be able to see whats under, so on the picture and visual inspection it will be perfect.
