Rear calliper rebuild kit
sohail_gtir
Anyone know if the rear brake callipers are the same on the sunny gti, my brakes seized up so looking for a kit to rebuild mine and the only kit I can find says it's for a sunny n14 gti, need to replace the bleed screw also, what size willi need.
thanks in advance
IIRC The seal kits are different because the piston size is different. - From Biggred (above) it's kit: BRK203410 (for a 34mm piston)
The piston (if you need it) is BRP233416
The GTi is BR203010 for a 30mm piston.
