JamesB
I have just has a surge tank and bosch 984 pump proffesionally fitted to my r. It was leaning out and detting at 1 bar with the old pump so i took the bleeder off until the fueling was sorted.
Now im just running standard boost with good fueling and on the odd occasion with WOT at 4500 - 5500RPM it will stutter one, two or three times then keep reving fine. No pops, bangs or detting - just a stutter (but more like a cut i think). On one occasion it did it at 3500RPM at maybe 1/2 to 2/3 throttle (it did a small pop then). To give you a better idea, it has happened maybe 5 or 10% of the time I give it WOT (but very random) over the last couple weeks.
The rest of the time the car drives perfectly - although Ive noticed the standard gauge now reads about 6.5 -7 instead of 5 - 5.5 like it used to. I have checked wastegate and boost signal hose - they're ok.
15,000kms ago replaced dizzy cap, all HT leads, dizzy rotor, afm (reground) and coil.
Less than 500kms ago replaced plugs (normal heat range NGK iriway), rocker cover gasket, fuel filter, oil filter, oil (Castrol formula R 10 - 60w), injector cleaner (twice) and always always 98RON fuel.
Have done fault code check - all clear.
I have no idea - please help :? :roll: .
James.
James.
