The fuel pump will usually run for a few seconds when you turn the ignition on. Listen for the pump to see if it works with the ignition on. Failing that take the cover off to gain access to the top of the tank and use a test lamp to check for power whilst cranking.
Or, find where the fuel lines attach to the fuel rail, crack off the nut if there is one and crank it and look for fuel (beware of petrol spraying, maybe use a rag). Might even have a schrader type valve which you use to read fuekl pressure, could always hold the valve core down while cranking.
Check your fuses aswell.
Jay
