Quick question
steve75
if the water pump goes does it leak water into the timing chain cover?
i had water in the Oil striped the head off flushed all the water pipes out an the timing chain cover filled up with water?
Gtirchris
Hey buddy, the water pump is completely separate to the timing chain cover, either when you flushed the pipes out it overflowed out of the water jackets and into the timing chest or you have dislodged a partial blockage that was sealing up a crack. either way you will now have a sump full of water, so you will need to drain the engine oil. If you are unsure whether you have a leak or not you can fill the water jackets in the block up and leave it for a few hours and then recheck it to see if the level has dropped mate.
steve75
thought as much all the water has now gone down so think i shall be removing the front cover to take a closer look hope i shall be able to see were it leaking from
