posted on the modifiers site for you
1st is longer. you should get 35 to 40 ish from first gear which you wont from a std. the whine is certainly noticable.The gearchange should feel slightly tighter compared to standard box, the gear ratio is slightly shorter apart from 5 which is the same is and they have a tendency to whine a little more than the standard box in all gears.........
Also sometimes you might see little tell tale signs of visible silicone gasket sealant round the gear casing joints
Think Stu would hear the wife whine much more than a lump of a box delivered... lolthat's only any good knowing that noise when it's fitted (and fucked bearing's sound similar too), if it's sitting on a garage floor looking at you will it whine then!! lol
Very true :lol:that's only any good knowing that noise when it's fitted (and fucked bearing's sound similar too), if it's sitting on a garage floor looking at you will it whine then!! lol
works every time :lol:;-)Can just say a swapped it for some parts i had ;-)
