q45 wiring?
nismoboy
ive done a search but no joy,Does anyone know how to wire a q45 to the pulsar?
One the mak each pin has a letter>
B left pin
D middle pin
E right pin
which one is, out put?supply? and ground?
JIMMYBACK
as far as im aware the q45 has only thre wires.........a constant live a semi permanent live(signal wire) and a earth.................. what ive been told is that the wiring is the same as a z32 maf except the z32maf has extra earths 8)
nismoboy
that still dosent help me as my q45 connecter is a ford plug and it has different coloured wires black,brown and green, what i need to know is if u look on the q45 afm theres leters B,D,E on the male plug on the side of the afm does anyone know what
B is ??? earth?supply? output?
D is ??? earth? supply? output?
E is ??? earth supply? output?
if anyone who has a q45 wired in could check on there a tell me that would be much appreciated. thanks
JIMMYBACK
if you have a voltage meter you can test it you self very easy :D
JIMMYBACK
Q45 (VH45DE):---------------------------------------------: (SR20DE) B13
Black\White-------------------------- (12V)--------------------Orange\Blue
White----------------------- (Ground)-------------------------------White
Black------------------- (0-5V Signal Out)--------------------------Orange
nismoboy
JIMMYBACK said:
The Q MAF has three wires as well:
Red = 12V
White = MAF signal
Black = ground
my wires are a different colour to that, i need to know what each pin is? then i can work it out.
i need to know what pin B,D,E all are?
nismoboy
thanks jimmy for ya help but ive now found out, for those who else may need to know its>
B= SIGNAL
D= EARTH
E= LIVE
:D :wink: Cheers nis.
