M4RV3
J plate black pulsar forsale. Breaks my heart to do this but my daughter comes first and the r just doesn't get the use it deserves. I have owned her since march 2005 from we're I have done no more than couple thousand miles. I always wanted one and I got one and spent the money on her and not towards a mortgage like my mrs says!!!!!!!!
here goes....
engine:
forged pistons Wisco 87mm
shot peened standard rods
Lightened balanced crank new bearings
lightened flywheel
tomei head gasket 1.2mm
jun 264 cams
new nissan rocker arms
nissan engine gasket set
exstensive head work
adjustable hks verniers
brand new nissan timing chain and guides
brand new oil pump
rocker stoppers
700cc injectors
uprated organic clutch
forge breather system
magnecor leads with high heat range plugs
tubular manifold heat wrapped
am performance 3inch elbow
zigen cat back exhaust
front mount intercooler
uprated fuel pump in tank
Blitz I colour boost controller
gt3071r
apexi air filter
air con removed Gti aux belt
gearbox is standard which was rebuilt by my colleague when I worked at nissan with genuine parts.
Gearbox, transfer box and rear diff have new oils and engine has had regular oil changes with expensive oils.
Brakes:
hi spec gold front calipers with grooved discs and yellow stuff pads
standard rear calipers painted gold with yellow stuff pads
braided brakelines with dot 5 brake fluid
Suspension:
d2 coilovers low mileage
full 4wheel alignment 1.5 negative front 1 rear negative
brand new outer front cv boots genuine nissan
Wheels:
ace wheels rare refurbished in kh3 wrapped in toyos tyres 300 miles max like new
Body:
bonnet spacers fitted
front bumper cut out for front mount
indicators front modification amber delete
rear indicator amber delete
side repeaters white with silver vision bulbs
headlamp protectors
battery in boot
Interior:
rear seats removed ( can obtain interior if needed at extra cost
standard front seats with 4 point harnesses
6 point roll cage around dash
D shape steering wheel
Car is not mot, taxed and sorn.
Body work wise the rear arches have gone rusty as usual and a few marks around car. Sills could do with replacing in my opinion.
i had my r mapped and set up by Jez at Horsham developments. She made 350bhp at 1.1 bar. He pushed it to 1.3 bar and made 400bhp but clutch isn't man enough for it so it was turned down. With a better clutch he reckons 450bhp which is even quoted on Horsham devolments website (customers cars).
As I said really don't wanna sell her but needs must
£3500 ovno
pics on request please text as not always able to answer phone
07968032673
here goes....
engine:
lightened flywheel
jun 264 cams
brand new oil pump
rocker stoppers
700cc injectors
gt3071r
apexi air filter
Brakes:
Suspension:
Wheels:
Body:
headlamp protectors
battery in boot
Interior:
£3500 ovno
07968032673
