problems
jaygtir1
:der: can anyone help? if i cane it round a corner or set of fast soon as the wheels spin it backs of which feels feirce whilst on boost and back fires untill i let off?:der:
nismoboy
fuel surge means your pick up on your fuel pump comes out of the fuel in the tank, this is caused by the fuel sloshing to the other side of the tank when cornering hard or accelerating hard.
u`ll need to open your tank up and check the pick up is still on ur pump, if it is then it just a case of making sure the pick up is mounted correctly so its always submerged in fuel.
jaygtir1
tell you what mate you could be right dont think it was that well supported when we fitted it and the problem isnt there all the time. am on with it first thing cheers pal
jaygtir1
looked at the fuel pump all seems to be ok only does it when the wheels spin well seems to
paz
Which direction corner are you going round? Fuel surge is a common problem on the R and happens even if the pump is fitted correctly in the 'standard' place.
Paz
