problem with maf???
Thor
hi,
i have a problem with my engine. when i set the maf option in power fc at vg30 with the (22680 30P00) Z32 the car runs bad. when i set the option RB25 it runs ok but is it possible that the Z32 maf is damage?? in one run from arround 2km i must change the options from VG30 to RB25 to VH41 that the car run to home without big problems. can anybody help me??
regards
sascha
Is your Z32 wired in correctly? Is it earthed properly? Did the car work fine on a standard MAF with the same map? If all answers are yes then there's a good chance your Z32 MAF is damaged.
Thor
the wire was correct fitted. with the standart maf it runs ok. so i believe that is really damaged...
Thor
yes i can see. but which values it must have at which rpm?? so when i switch the ignition on (the engine does not start) the value is sometimes 480mv, 690mv or 780mv.
