after ignoring others better advice i removed an aftermarket chip from my ecu. it was a field boxer chip and was soldered onto the ecu on the points shown below...
i didnt attempt to de-solder the wires as they were so small and didnt want to risk melting the circitary on the ecu, so i just cut them. none of the wires are touching as they are all encased in a paper casing.
refitted it and when i turned the ignition on the fans came on straight away, it started but ran mega rich black smoke, stinks of fuel. there's virtually no vacuum as the boost guage shows only -100 and its idling very low on 1000rpm but as the engines cold and mine runs normally at 1300rpm lowest its not right, and its just struggling to run rally erratic.
i havnt touched under the bonnet, but have dismantled the centre consol.
i have a avcr and safc also plumbed into the ecu, both are getting a signal but the safc has no imput as i tried ricening and leaning out the idle to see but nothing happened.
any ideas to what ive done.
help...please
help...please
