Hey, Can you tell me if the power steering on GTI-R is naturally quite heavy?? Cheers kev.
A Anonymous Guest Mar 30, 2004 #1 Hey, Can you tell me if the power steering on GTI-R is naturally quite heavy?? Cheers kev.
Fast Guy Moderators Staff member Mar 30, 2004 #2 Mine isn't. Check your fluid level and belt tension are OK.
A andygtir Member Mar 30, 2004 #3 check your tyre pressures as well, if you're running wider wheels than standard this could effect it too. you should be able to turn the wheel with one finger when stationary.
H hmmm Member Apr 1, 2004 #4 ... mine is also a bit on the heavy side. pls let me know how u sort it out so i can try and fix mine too. thanks
A Anonymous Guest Apr 3, 2004 #5 Cheers for the replys. Actually think its fine just a bit para i think my mechanic friend said it was fine.
J jasegould Guest Apr 3, 2004 #6 Yeah, its not as light as modern cars but i prefer it as it has a bit more feel
