power steering fluid
Gaz gtiR
just need to top my power steering fluid up but what is best to use? dot 4 brake fluid or transmision oil? the stuff in at the min is red. & my gear box oil ive got is silkolene race syn 5. ive got some spare so am i ok using that or not?? its on the bottom of the cold mark on the dipstick on the cap. so only needs topping up very slightly.
Gaz gtiR
ok am i ok topping it up with silkolene race syn 5. which is (Fuchs titan race syn 5) theyve just changed the name. its what i use in my gearbox. as it only needs topping up a drop!
Spikey
You cant use gearbox oil for the power steering. smell it and if it smells like kitten pee then its gearbox oil .
So DON'T USE FOR POWER STEERING.
Power steering fluid is normally automatic transmission fluid. I'm not sure your gearbox oil is ok.
Jeeeezus... just buy some bloody power steering fluid; your local servo will sell it (and I'm pretty sure you can pick it up in most large supermarkets too), and it will come in a smaller bottle than ATF.
As above: DON'T put brake fluid in. DON'T put gearbox oil in.
Do not over-fill it. If it's on the cold mark when cold, and the hot mark when hot, that's full already and doesn't need any topping-up!
