Power loss!
turbazz
My car has been running fine pulls through the rev range strong..
Recently I've been fiddling around with the O2 sensor as I discovered it was dead! Found the issue the wire was broken.
So soldered it up it was sorted ! Given me a reading.
But my car performance dropped! Car felt the same till about 5000rpm then theres no power.
I Haven't touched any other part of the car simply just the sensor cleaned it fixed the wire.thats it.
So I thought it might be a faulty sensor il just disconnect it again then I will be back to normal. But no car remains the same.
Any ideas guys?
Is like i have upset something through the sensor. If that's bloody possible
I know I did mention this in my other post you suggested to check the engine temperature sensor.. But I still can't get my head around car was working fine before touching the sensor.
Unless it is a big coincidence
