Power loss
F
fkw17
hi there got a problem with my R,
As I hit boost I notice that there no power through the rev range. You can hear to the turbo spooling but the car is not going hard as it should. Could the timing be out? Or the ignition leads dont have enough spark? Anyone that help will be great. thanks
mods: standard turbo
fmic
534cc injectors
fuel reg (3bar)
exhaust
boost controller (12psi)
Animaldaz
Sound like a Det sensor fault, do a fault code check. Or a boost leak, check all your pipework and hose clips.
m.r.motorsport
What is the correct timing for an R. and where can i find out what timing is needed for minor mods?
