power loss
H
Hedlund
yes guys, as the topic says....
somewhere in the engine is something wrong....My friend in Sweden had 2 gtir`s for some time ago also completley original, and they where alot faster or something is steeling power, I have air conditioning but I never use it.
Does someone know anything that can help me out?
// Daniel
stomski
loose MAF sensor?
over fuelling?
in need of some TLC - good service with performance parts?
loose some weight after xmas!!!!! :D
get it on the rollers at your local tuner, they should be able to tel you mate!
Your description is to the point at least. :p
Are there any noises from the engine now, misfire, backfire, knocking....etc
Did it just happen or happen over time?
Check all your boost hoses are connnected.
Do a compression test.
Check the ignition timing.
Check the emissions.
Check the cam timing. (long shot)
Take it to a garage :wink:
