Power FC = Std map?
Fazz
does it matter?
if you have a power fc then you will want a good map on it properly tuned.
Not much point having it otherwise is there???
PS - if you are running with it fitted and not mapped, if the engine light flashes that means detonation.... this is bad...
H
HKS-Fan
My std. ECU died last week.
It is not worth to get a second hand one, which will cost me about 50 Pounds and still has the speed limiter in it. I want to run a bigger turbo in the near future, so I have to buy the power FC.
Fazz
thats a funny logic mate!
There are a good few options out there - emanage, aems, even SAFC depending on mods.
And 50quid for a standard ecu wouldn't be the worst would it?
You'll be looking at least 600 for Power FC, and another 400-500 on a good map...
Then a remap when you get turbo etc...
I'd get standard ecu till mods at stage of ecu required..
H
HKS-Fan
I think your messing the main point...
That`s why I asked if the power FC has the std. map.
Cause I know that it isn`t worth mapping the car on that stage of tuning.
