Possible SAFC2 Problem
D
DOT2DOT
Just got an SAFC2 and wired it up. Performed the intitial settings, but left all the other settings at 0 untill i get a wideband and det sensors. Since doing it, the cars been down on "off-boost" performance, especially under load at low revs. Anyone experienced anything like this or have any ideas?
jiw
Check the connections on the yellow and white wires (the ones that intercept the maf signal) jeff :wink:
buffalobilla
did u cut the orange cable on the ECU and wire the input and output air flow wires correctly? :shock:
D
DOT2DOT
Yes , its wired ok. The car drives almost perfect, but theres just this slight hesitation/restriction under load at low revs. Dissapears when i disconnect the safc. Its as if its being bogged down a bit. Ive just left it disconnected until i get it set up now. Then i can blame that guy if its not running right. lol
