D
dick dastedly
ok the car is running fine with no smoke on tick over or off boost running but if you floor it it smokes alittle then a big puff of blue-white smoke as you lift off will this be turbo and how can i check as i dont want to have it re done if thats not the prob, done compresssion test and thats fine. also does the oil escape into the inlet side or is it just burnt on the exhaust side if you know what i mean or does it do both and can a standard turbo be built using roller bearing or am i best not having this one re built and buying a standard turbo new???:der:
