porting original manifolds
kirko
where can i get info on porting my original exhaust manifold and converting it to external wastegate, i have done loads of mini heads and manifolds just need to know what works best for GTIR's rather than the trial and error method
Simon Norris sells one pre done I think, so he'll know (maybe) but I doubt he'd give you much info as he'd rather sell one, (at a guess)
I'd just say try the usual, clean up any casting marks and match it to the gasket lines. :wink:
K
krikra
Im going to do the same when I fit my new turbo.. Was going to post the same question.
Isnt NAD using a ported standard mani? Could just be one from Norris..
ashills
standard manifold will keep flowing upto the 500s if u really push it but after 420 ish they say its best to get it ported
I did mine myself wasn't to hard a job really :wink: .
Just get yourself a dremmel :lol:
rob
Nad
Gave up waiting to have mine done so doing it myself now. Not sure what I am doing about the wastegate at the moment, ie position.
Nad
K
kizzyturbo4x4
im starting build of my new engine and im getting the haed ported up,
so if i just port up the standard manifold to match how much power is it good for? :)
must be better than other afm ones, that break after a feew weeks anyway.... :x
kirko
is there an optimum place for the external wastegate take off?
im aiming for about 380 /400 bhp so do i need external wastegate?
hmmmm...... decisions :?
GINGA
think most are taken off the hump in the middle/top of the manifold.
You'll get that power easily with a internally gated turbo no probs at all wouldn't bother with the external gate tbh unless your looking for serious boost/power with a big turbo, unless you just want tit for the noise :wink:
Mr GTiR
Im aiming for that sort of power and have an internal wastegated tubby. All i've had done on mine is to open up the ports a little to match the gasket.
j10gtr
I had a standard turbo manifold milled for a pipe to fit an external wastgate on for surry. He then had a right angle pipe welded to the standard manifold and a flange for an external waste gate on the other end.
It worked Fine
Car mad very good power ( neerly 400 at the hubs) but unfortunately it wasnt mapped right
I have also ported my own manifold but its a bit difficult to get all the way through the runners.
Thanks
Paul
K
krikra
"A bit difficult" :shock:
Its impossible! at least with a dremmel like Im using.. Even with a "flex arm"(?) its really only the opening that can be done :cry:
Paul R
Thats what they have on the standard scooby (non-wrx) isn't it? Not roller bearing though. I'm guessing the rest isn't standard either?
Nad
It worked Fine
Thanks
Paul
What sort of welding was used??
