plugs
stuarty
Ok just out cleaning the plugs and found that 2 of them were coevered in oil......is this normal??
If you are looking at the engine from the front first on the left had alot of water in the well then the 2 was clean and the other 2 were covered in oil ..............anything to worry about??
Non of the plugs should have oil on them, I'd do a compression test on the engine fella, Your rings maybe letting oil past or the stem seals could be buggered.
A comp tester lol, You can buy them for under £20 from most proper car part shops, even halfords.
