boucherie
Further to robs plenum spacer ive been doing some calculations to see if it will be worth looking at having some made up.
The internal circumferance of the plenum (around the gasket) is 89cm which equates to a square of 22.25cm
therefore the surface area would be 22.25 x 22.25 = 495.0625cm2
by making up a 1" spacer the volume it will hold then becomes
495.0625 x 2.54 = 1257.49cm3 or 1.257litres
The top of the plenum chamber holds 2.5 litres so therefore a 1" spacer will increase the volume of the plenum chamber by about 50% by my calculations.
Can someone dbl check this and confirm/deny if thats correct or not.
If it is correct then who wants to get them made up!
