R
RJC
I've had my pulsar for 3 weeks now, and I've put a couple of posts about a problem I've got. After getting used to it for a bit hopefully I can describe the problem so somebody who has had the same problem before and can help me work it out.
The car is a fresh import, and 100% standard and unabused.
The dials all tell me the car is ok, (the oil pres riases when you put your foot down for a while, but I take it this is normal). The intercooler is not overheating, and I'm pretty sure all the turbo pipes are not losing pressure.
The problem is that when I drive the car slowley through town, and/or following other cars without useing the turbo in a gear so the revs are not high for roughly 20-30mins, when I get the chance to put my foot down it dosen't pick up as it should. The car seems to lag more, and even feels like it's slowing breifly, then it accelerates but it doesn't feel like the turbo is working, although the guage shows normal boosting. I know when the car will do this because when driving through town if I gently accelerate untill the turbo is starting to take effect, it jerks a bit and power loss is felt when I'd expect the turbo to pull.
When driving the car hard, or on dual carriageways it's fine.
I'm going to change the plugs, fuel filter, and upgrade the airfilter.
I haven't tried doing the fault code check as I don't know what I'm doing there, and worry I could mess something up!
Any help would be greatly appricated.
