N
NEIL R
Started first time as normal but then would not rev then cut out now it just turns over could it be my fuel pump how do i check.
The fuel pump will usually run for a few seconds when you turn the ignition on. Listen for the pump to see if it works with the ignition on. Failing that take the cover off to gain access to the top of the tank and use a test lamp to check for power whilst cranking.
Or, find where the fuel lines attach to the fuel rail, crack off the nut if there is one and crank it and look for fuel (beware of petrol spraying, maybe use a rag). Might even have a schrader type valve which you use to read fuekl pressure, could always hold the valve core down while cranking.
Check your fuses aswell.
Jay
_________________
SPONSORED BY DURACELL
No noise from pump and no fuel coming from fuel pipe running to the fuel rail also taken spark plug out turned it over and there is no petrol smell i just dont no were the fuse/relay is for the pump so i can check that anbody got any other ideas.
I have now removed the pump :shock: put power to it and it span as though it is working now i am really stumped could do with knowing were the fuses or is there a relay and how you check a relay as they are normaly a sealed unit as it must be fuel related but have half a tank:?:
