Im looking to take the plasic trim off that is located under the wiper arms where the water runs down from the window screen.. there are about 6 plastic pins holdint it on ?? how are there removed as there is no head on them..??
I'm looking to take the plasic trim off that is located under the wiper arms where the water runs down from the window screen.. there are about 6 plastic pins holding it on ?? how are there removed as there is no head on them..??
You need to put something thin under the plastic panel right by each of this clips and gently pop them off, I did it carefully with a screw driver, You just pop them back in when you re-fit the panel.
